ph billet 路
Sorry it took so long but here is my hinge pin removal tool this tool will get out the stubbonest pin if this fails the only way is to drill them out. NOTE..the pins marked ''A'' are different lengths from 25mm to 60mm long when you run out of travel on the screw put in a longer pin I used standard dowel pins here as thay need to be hardend.The M12 tapped hole in the centre is for a long bolt to act as a handle.Also be careful as the hinge pins have a straight knurl on one end I think it is at the top so push from the bottom up, anyway no garantees this will work for you but it worked a treat on my doors.
