help!!!!!!
https://forums.aussieveedubbers.com/threads/2300/help
kombi_kid ·
hey can someone tell me my next step?????? have tried jacking the spring plate up and using the screw drive as a ramp.????????
Baja Wes ·
Move the jacket further down the spring plate, as close to the wheel end as possible. This will get the greatest leverage on the springplate and get it off it's stop.
Once it is off it's stop, try the screw driver trick again. try and lever the spring plate over the stop. It'll eventually move.
Also try tapping the end of the torsion bar with a hammer as your levering. It will help break the bond between the torsion bar and the spring plate.
[Edited on 11-12-2002 by Baja Wes]
baybuscamperkid ·
ive just done a similar thing myself, and if u dont mind taking the torsion bar out as well, then reattach the springplate to the hub, disconnect the drive shaft and use the weight of the whole getup along with your own grunt up and down and outward and u will get it b4 too long. its a bitch of a job, but that seemed to me the easieas way if u dont mind removing the lot.
kombi_kid ·
hey
i have had it over the edge but it wouldnt drop anymore cause of another spot was catchin on it ill try and get a photo!
rhys
kombi_kid ·
it get sorta caught around where that weld runds down (where ive circled)
kombi_kid ·
hey
this is how im doin it.
screw driver at the top and crow bar at the bottom and a jack at the end making it level.
56astro ·
Hey Rhys
Remember when we did Jack Frost's we used a couple of tyre levers (top, bottom and from in front) and just kept wriggling the spring plate. Try tapping the spring plate near the torsion bar, as mentioned above.
Then once the spring plate looks like it will clear the stops, let the jack down so that all of the weight is off it, by about 5-10mm. Then put some leverage into the wrecking bar you have and hey presto.
Sounds easy, if you get desperate give us a ring and I'll try and slip up.
Baja Wes ·
just hit the end of the torsion bar with a hammer while someone is levering the spring plate.
kombi_kid ·
hey
thanks heaps will try it out this morning!
rhys
p.s. thanks steve
Rhys
BE CAREFUL AS THERE IS HEAPS OF TENSION ON THIS SPRING PLATE
KEEP YOUR FINGERS CLEAN
THEY USUALLY GO OFF WITH A BANG !!!
spray some WD40 lubricant onto the end onf the torsion spring as well while your using the pinch bars etc
kombi_kid ·
soaked them last night with INOX
rhys
kombi_kid ·
there out 😀 thanks heaps steve!
rhys
p.s. thanks for all your inputs
Rhys u still got 8 fingers ???
did they go OFF with a BANG ???:puke:puke
kombi_kid ·
yer still got all my fingers i had to pull out the torsion bars aswell . im lowering it using them anyway so its not real important where i put them!
know to go and get some new bushes.
rhys
WHAT ???
""" so its not real important where i put them! """
kombi_kid ·
ahahahahahahahahaha
i meant like where the splines go on the inner (left one to left one right one to right one)
rhys
kombi_kid ·
ahahahahahahahahaha
i meant like where the splines go on the inner (left one to left one right one to right one) and even on both sides 😉
rhys
