I'm not sure what the stock T1 compression ratio is, but the EJ20 n/a has 9.7:1. I've read on the vanagon forum and a few other places that the stock T1 starter motor isn't up to the task.
What are you guys using?
CBB use a reduction starter motor that they fabricate in their exotic conversions.
I believe they have sent them out to people with V6s, V8s etc.
Jenny ·
Ok I've found some more options:
1. WES wrote somewhere to use a battery with a higher cold cranking amps rating, I think he's using a 520CCA battery with a stock T1 starter for his V6 conversion.
2. Another option is to use a semi-auto starter, as per this thread. http://www.shoptalkforums.com/viewtopic.php?t=66664
[Edited on 18-5-2004 by Jenny]
MikeM ·
I'm looking at bringing in a group buy of high torque starters into Brisbane.
I actually using a stock 2lt starter, which I think has the same motor part as the type 1 starter, or similar power anyway.
It cranks my 10:1 2.5lt V6 no problems. I do think having a decent size battery helps, I have a 520cca or somewhere around there.
A number of places in australia sell the hi-torque starters. I didn't want to go that way if I didn't have to, cos I didn't want to break or damage my ring gear (which is set-up in a weird way that it wouldn't be as strong as the stock set-up).
seagull ·
Jenny I sent you a email to day I hope you got it re a cheap starter near you , neil
humpty ·
I hear 911 Porsche starters from 79 to 84 fit straight into bus boxes and I now Bosch are now making hi-torque direct replacement starters for all other VW's. You should see these things....TINY! About the size of a coffee cup. Apparently they make just one motor now for all cars and then stick the appropriate drive to fit what every car!
That said, we have run a stock T1 starter with a RS turbo engine. Not sure of the comp ratio, though suspect around stock VW or simiar!
Not much help I know!
Jenny ·
How can you tell the difference between a stock starter and one from a semi-auto?
In this link, the standard one is on the left and the auto one is on the right. The standard one has the shaft extending out past the gear and has a bush fitted http://www.bus-boys.com/starters.html
humpty wrote:Bosch are now making hi-torque direct replacement starters for all other VW's. You should see these things....TINY! About the size of a coffee cup. Apparently they make just one motor now for all cars and then stick the appropriate drive to fit what every car!
Cool, any idea where I can get one of these new mini Bosch starters.
[Edited on 19-5-2004 by MikeM]
humpty ·
You are correct Jenny.....Are you running a Bus box are T1 IRS?
If UR running a bus box, at the very least I would look at the post 86 bus starter, but I can get a 911 starter secondahnd for $250 here in Perth.....
Loads more torque than the standard VW starter.
As for the new Bosch mini starters Mike......
Your FLVWS should be able to get one for you, otherwise try Tooleys in Sydney....
I think they import them.
Later
[Edited on 24-5-2004 by humpty]
seagull ·
Jenny have you found one ?? let me know seagull
Im pretty sure that the semi auto is the same as a 911 starter.
The stock starter is .7 bhp, the auto is .8 bhp
1302Steve
humpty ·
Steve maybe right...I have heard this B4, but have yet to confirm.
Jenny ·
Hi Humpty,
I'm running a T1 IRS single sideplate box, supposedly built by Henry Spicak with beefed up internals and a heavy duty clutch.
I was able to turn over my WBX with 10.5 comp no worries with a stock starter, it was even better with an auto one.
