Lowering the front suspension
https://forums.aussieveedubbers.com/threads/23140/lowering-the-front-suspension
battybat ·
Hi!
been going through the forum looking for posts on lowering, any advice, good sites, good kits?
while I have the bug in bits (replacing the pan) I may as well get on with all the things I want to do - want to go down about 2 - 3 inches at the front, keep the back stock (mainly cos the back wheels are only just in there, and I like the way they fill the guards)
it's a 69 beetle, 205/70/14's on the back and 195/70/14's on the front, and as soon as I get back from the UK in June it's going to be in bits all over my garage!!
Terry
4 of 50 ·
Looks great but can ride rough/bumpy, I'm going back to pre-low rider days on advice from my orthopaedic surgeon.
just remember when you lower the front the rear will actually raise ! So if you want the stock height at the rear you will also have to lower the rear ! make sense?
Oasis ·
Get dropped spindles, that way you keep the same suspension travel (same length shock absorbers)
lugnuts ·
What ^ said 😉
Oasis ·
Here's a link: http://www.cbperformance.com/catalog.asp?ProductID=478
battybat ·
Craig Torrens wrote:just remember when you lower the front the rear will actually raise ! So if you want the stock height at the rear you will also have to lower the rear ! make sense?
yep, so I need a kit to do the whole lot then?
preferably Australian too, I object to buying american when there are home grown options
buzzbug ·
the advice that i was given was wait till the car is all back together so you know how it sits with everything in it.
I have lowered mine about 3 inches all round and the back is great but the front rubs slightly when i hit some bumps. I am now contemplating narrowing the front and fitting drop spindles and adjusters. ATM i only have adjusters and it rides a little rough but handles like a go-cart.
battybat ·
cool
spose it would help if my wheels actually fitted INSIDE the rear guards! but I really like the way it looks
drop spindles sound like the way forward
battybat ·
and the rear view....
buzzbug ·
dude i have 195'son the rear which make them fit really snug under the back.
they don't rub at all.
maybe if you just swap the tyres front to rear just to see how they fit.
then get some 195's for the rear.
wacked1 ·
i have an adjustible front beam for sale that will fit your car in good condition, if you want it it's cheap.
u2u me
battybat ·
you have u2u wacked1
buzzbug ·
how did you go dude?
oval TOFU ·
hey battybat
my 225/60/15 rears look like that on my oval too! I havent had any rubbing as yet coz its stock height and I haven't carried any bodies in the back yet...
ph billet ·
did battybat buy that beam if not how much do you want for it U2U me thanks.
