Won\'t idle, sometimes
https://forums.aussieveedubbers.com/threads/23685/wont-idle-sometimes
Spook ·
Righto, got a 1600 single port in the kombi, stock as the proverbial rock.
Kick it in the guts & away it goes, but once it warms up, it may or may not idle.
Bastard picks its moments, stop in the driveway, it will idle, stop at a set of lights it wont.
Touch the throttle & it will rev, but turning up the idle does nothing.
I cleaned out the carby & changed the fuel filter. No difference.
The bloody thing runs like a bird, it just wont idle.
jnr356 ·
blocked idle jet?
valve clearances too tight?
Che Castro ·
its not icing is it?
Baja Wes ·
it's not simply the idle shut-off solenoid playing up is it?
Desert Moose ·
or maybe a lose wire to the solenoid
splitbusaustralia ·
If it stops on deceleration (like coming up to a set of lights)
but will then start and idle its the idle circuit....clean (blow thru
might do) and adjust?
RobK
VWFREAK ·
check the idle jet. It may become blocked with crap from your tank crappy fuel etc) or fuel line deteriation.
