Im sure someone out there knows how to remove doors. I haven't touched them yet dont want to screw it up.
Any ideas?
Liam:alien
Liam
I would start by spraying some penetrene on them, and allowing it to soak for a few days. From memory they are Number 4 cross recessed screws, or phillips head which ever u prefer.
If you can find a screwdriver with flats on the shaft, then you can add some extra leverage using a spanner on the flat section while your pushing the screwdriver.
Another trick is to place a bit of valve course valve grinding paste on the tip of the screwdriver so it grips into the screw recess. this stops slipage
