who sells front beam ajusters
https://forums.aussieveedubbers.com/threads/23823/who-sells-front-beam-ajusters
Secoh ·
to suit a ball joint '68? VVDs or Mick Motors? I couldnt see them on the MM web site and custom offroad sell the whole front beam exchange.
custom offroad looks the easiest except for the cost of sending them back and forwards from QLD...
thoughts?
VVDS has both types available I just rang for you.
They type where you cut the beams and weld into position are $36.00 +GST each
and the Avis type where a larger slot is required are $127.00 +GST each
ring 9789-1777 if you want to order both in stock.
MikeM ·
Who is VVDS?
[Edited on 3-6-2004 by MikeM]
Secoh ·
Thanks Dave, muchly appreciated! any advantage over the two types?
Mike, their web site listed it at about $220 exchange I think.
I have not fitted the AVIS type but i believe that you have to enlarge the slot or hole thats already in the beam, so that means theres no cutting and welding or realigning or getting the beam twisted, Ring Vintage Boris and talk to him he will advise the method of installation.
lot of extra work with the welded ones... lots of things to go wrong if you have not done before.
