Can someone please post a step by step on how to reduce the kb size of an image.
I have tried a couple of times and can only do it when uploading from the camera itself, so if it isn't alreadt in the camera I can't choose to have a reduced copy made at a lower quality.
I have photoshop 5.5 and 6 which should do it but can't figure out how to.
Any help would be appreciated.
slow n low ·
Steps (1 method)
1) Open your image in P.Shop
2) Click on the image Tab and then Select Image Size
3) Make sure constrain proportions and Resample image are ticked.
4) Resolution doesn't have to be any more than 72dpi for the web.
5) Make the image a nice size say 15cm wide in print size.
6) Click O'k
7) Go to the file Tab and click "save for web".
8) click on the 4-up tab
9) On each tab their should be the size that the image will end up, click the one equal to or less than 50kb.
10) if you want to be a bit more of a perfectionist you can nudge up the qulaity bar to the right hand side of the window until the photo is a close to 50kb as possible.
11) This should work
Cheers Damian
slow n low ·
here is the image size window
slow n low ·
- it won't let me print a screen shot to show this menu, but you should be able to navigate it fairly easy.
-if you wont to see all of the photo in this menu you can change the zoom in the bottom left hand corner.
Cheers damian
Grey 57 ·
The best jpeg cruncher I have found is on Corel Draw. Takes them from 150+ down to 20 or 30 with one mouse click brilliant.
Mad Manx ·
I have photoshop 5.5 and the easiest way
I found was to go to 'file' and click 'save for web' ... this new screen will show your photo in the exact size it will apear on the net. To reduce it click on 'image size' and reduce the percentage..... easy
KruizinKombi ·
If you are running Windows XP you can download a Powertoy called "Image Resizer" from here:
