Vinyl spray seems to work pretty good
https://forums.aussieveedubbers.com/threads/24049/vinyl-spray-seems-to-work-pretty-good
I sprayed the back seat of the beetle on the weekend with some vinyl spray. I changed it from red to black to go with the rest of the interior.
I must say I was actually surprised at how well it came up and how resilient it seems.
I had a real work on the dub day.
-I replaced a battery terminal,
-painted the back seat & fitted it
-fitted a new petrol flap release handle WCM
-put carpet on the board that sits in the front luggage compartment.
-replaced both headlight wiring tubes WCM
helterskelter400 ·
the bro did his bay camper with vinyl spray. its survived one trip round oz plus a year with kids. gotta be OK, eh????
I wonder if the vinyl spray will work on my skirt.
Whoops did I just say that?
helterskelter400 ·
yep will work OK.
if you want it to take to your rubber fetish stuff, you'll need to roughen the surface a bit.
use you teeth bad boy........
Even on PVC hotpants. 🙂 🙂 🙂
helterskelter400 ·
the question is....
how much do you make them streeetch?????????????
if its only the av stretch then its fine.......!!
silver ·
Viponds paints in Bankstown has all the good gear for vinyl paint they sell paint, prep,and etch for Vinyl, stick it in your own spray gun, I have sprayed headlinings with this stuff and with a good gun you can achieve a very good result
S
