does any know where i can get 15" alloy wheels for my baja bus i have asked a few wheel mobs with no luck but i have seen heeps of baja busses with them i am runing 15" merc rims with 11.5r perrelis and hub caps" not as cool"
thanks
t2 ·
obviously dependending on how high the bus i would go for something different to what you have seen on other busses ,i have been trying to convince a guy i know with a baja bus to stick some 24 inch chrome rims on his just for street use and keep his merc rims for other uses like off road. he is looking at the moment and has found a set but found that they are hard to get in 7 inch width and are very expensive but how cool would they be.
if you are in sydney try cbb or a big tyre place like tempy tyres if they dont have it no one will
wacked1 ·
I've been through this my self, you can go as you know Merc, Audi A4, A6 mine are built for a Kombi i run 16 inch diameter by 7.5 wide and i think there is a large selection of tyers to suit the larger diameter wheels now so look around at the tyre shops and see what they can do , keep an eye out in the trading post as well, places like CBB don't have much in the wheel department i've asked these guys for the past year and all they could suggest was to do a studd pattern change. check out brads ( I think) dads bus it looks cool with audi rims.
hope i could help
here are my rims
Brad ·
check out the article on www.aussiekombicampers.com there is all the info you need. I have 16" rim son my dad's bay and you canget them of Sherman down the coast.
sand kombi ·
Just be careful if you are going to use the bus offroad, as if you hit a pot hole, submerged or hidden rock or go off a cut out on the beach and land heavily, as I did on Double Island, you may damage, crack or shatter the rim. Then you are really up the creek with out a wheel to paddle with. When I damaged mine being steel I could panel beat it out(I just bent the rim edge), so just take this into consideration
:beer
wacked1 ·
too right, you do need to keep the repair and cost of alloy rims in mind
11CAB ·
I'm running 15x7 Ford mags on our Baja Bus, had the holes offset my 1mm to fit and they cost me about $75 a wheel
