what gets grease off carpet ? HELP * fixed *
https://forums.aussieveedubbers.com/threads/24386/what-gets-grease-off-carpet-help-fixed
seagull 路
what gets grease off carpet that will not leave a stain ? its cv black grease on light grey carpet , cry cry:cry
[Edited on 14-6-2004 by seagull]
[Edited on 25-9-2004 by seagull]
Dannyboy 路
Good luck! Have to laugh as i did the same when i was cleaning my engine lid whilst watching tv on Sunday! I used some prepsol which got it off a beige carpet. Worked but maybe a carpet spot cleaner may be less harsh
Dan馃檪
[Edited on 14-6-2004 by dannyboy67]
seagull 路
aaaaarrrrrrrr new car !
lulu94 路
dont know if it would work but i know it doesnt stain.
my mum always uses washing powder in warm water, gets just about anything out, but im not sure about grease, worth a shot though.
Danielle
KOM123 路
A nice rug :thumb
pod 路
new carpet:P
or maybe a pair of scissors馃槈
[Edited on 14-6-04 by pod]
Spook 路
Go to a carpet shop & ask for a product called 'drisol' (pronounced dry sol)
I don't know if it's available to the public, we used to get it as tradesmen.
It's the only stuff I know will remove grease or oil.
seagull 路
Hey thanks all , all because a near head on with a truck on the wrong side of the road aaaaaaaaaaaarrrrrrrrrrrrrrrrrrrrr .
5PL1TDCS10N 路
I thought you were building your engine in the lounge for a moment there N! haha...
Wax and grease remover|prepsol is the best to use, but try on a small area first to test... and when its all clean afterwards use dishwashing liquid to wash the wax and grease out(it will eat through the fibres otherwise)
Glad you're safe and got away from the cops though....I'll pickup the stuf from the safezone....
ducky 路
i'm confused is it car carpet or house carpet?
KruizinKombi 路
Dry cleaning fluid and elbow grease......
vwombat 路
I did my CV's a couple of weeks ago, and someone walked little dots of grease onto the house carpet. We used a pair of nail scissors and cut the little globs out. Worked fine, and you can hardly see the bald spots at all!
Good tips from everyone else tho'! Taa!
killakornkobb 路
i've used WD-40 :| it worked.. then warm water to get rid of the slight smell 馃檪
last celtic warrior 路
Preen. Test first, but I've always found it a miracle in a can. Spray it on and wipe it over with a warm wet cloth to soak it out.
Appearantly works a treat on oil and grease on overalls too, but that's probably an old wives tale...
vwombat 路
Apparently, if you wipe a bit of cat crap onto another part of the carpet, the grease spot's don't seem to be as important an issue anymore?
Never tried it tho'!
seagull 路
I did the WD 40 worked a treat , Thank you :beer
killakornkobb 路
no probs mate馃檪
