Okay people, the time is rapidly approaching for me to replace the clutch in my L bug, as the second hand one that I put in 18 months ago is beginning to slip more than I like to put up with. I've looked around perth, and everyone quotes around the same price, about $200 - $215 for a Luk clutch kit (diaphragm style 200mm pressure plate, sprung conventional friction material clutch plate and new throw out bearing) + german rear main oil seal and flywheel oring (which I will replace at the same time).
Seeing as I am running a mild 1835 with kadrons, counterweighted crank etc and I enjoy giving a bit of a flogging from time to time, is it worth my while shelling out the $$ for a modified / heavier clutch or not ?
What are peoples experiences like with the Luk brand ?
Do I need to drop the oil out of the motor to do the rear main seal ?
I plan to pull the motor first and check to make sure its not just an oil leak back there (it doesnt feel like it though).
Thanks in advance for your advice and help.
Doug Sweetman ·
