I looked at my fuses today and it seems that whoever changed them has screwed around, for instance i took out a ceramic piece that said 25, so 25 amps, and the metal was the same thickness as an 8 amp fuse. How annoying. So I dont even know whether they are the right rated fuses. Nothing has blown though...
Does anyone have a diagram of the fuse box in a '69 bug, showing the type of fuse needed for each spot? Or can anyone tell me what they should be?
I have checked vintagebus.com, doesnt have it.
REd fuses are 16amp and whItE r 8 amp
The headlights and parkers all should have Whites in them so you should only have about 4 reD fusES fitted.
OtHeR WisE soMeThInG else is WrONG
oval TOFU ·
look up HBbear (or something like that) he print you out a wiring diagram upto A1 if you want... i got an A2 for my 54... nice and clear too!
dak dak ute ·
just because the metal appears the same... it may be a differnet material.......
oval TOFU ·
My 54 beetle only has 3 fuses instead of four! Am I in trouble?
