After buying my '72 Kombi last weekend and driving it back from the gold coast to Sydney with no problems (apart from burning a bit of oil (bad smell) and sluggish performance (dizzy/carb problem?)) I went to drive it this weekend and it wouldn't start :cry
It tried to turn over for a spit second and then stopped. Im getting the lights coming on on the dash and the battery meter says its charged. There's not even a click from the starter... I tried cleaning the terminals up on the starter motor but still no joy. I tried putting it in reverse and giving it a godd rock backwards and forwards to see of the starter motor was locked. I was advised by someone to short the terminals on the starter motor with a spanner, this did cause the starter to click (along with a nice big spark so I wont be doing that one again). Does this sound like the starter motor or solinoid is stuffed or could it be a connection not being made in the ignition barrel?
Any ideas would be much appreciated before I start buying new bits to try and sort it out.
TIA
Ian
[Edited on 29-7-2004 by Bu99ed]
[Edited on 9-8-2004 by Bu99ed]
Che Castro 路
hehe ive done this before too 馃檪
I accidentally shorted the two larger terminals on the back of my starter which is wrong and it arced about 2 inches from my face which isnt a nice experience!
If the starter clicks and turns then I'd guess its the ignition switch, my one did this once. It went away after i inserted the key and tried again and again
Bu99ed 路
Cool 馃檪 A barrel change is a lot less messy than a starter motor so Ill be giving that one a go first 馃檪
Cheers Castro
mnsKmobi 路
Bu99ed wrote:..snip..
TIA
Ian
If the problem is the ignition switch, shorting the terminals at the solenoid should cause the starter motor to turn over. If understood you correctly this didn't happen. Either there is something wrong with the starter motor or the contacts inside the solenoid are dirty.
Che Castro 路
Yeah if the spade terminal and the big terminal are shorted with a screwdriver and u just get a click, then its the solenoid - it isnt able to get far enough to engage into the gears and start turning over the engine.
I went for a while in my car with an old battery and tired starter and every now and then it'd just click and after a few tries it started. I got sick of this so i went and bought a new battery, rebuilt starter and now it spins much faster and starts first time every time.
check your battery. You should ideally have over 13v when the car is off
Bu99ed 路
The battery meter reads over 13v when its off so I assume thats OK.
mnsKombi: Do you mean that shorting the terminals would actually start the engine? The starter did make a clicking noise but I didn't keep the spanner on long enough to give it a chance for anything else as the sparks scared the crap out of me and I hate dicking about with electrics.
Sounds like it may be a good idea to rebuild the starter anyway. Is it a complicated job or just a case of pulling it apart and cleaning the terminals up?
LoL you wouldn't believe I split the case once and rebuilt the engine would you... cant wait till my keeping your volkswagen alive book turns up so I can start messing about things with confidence 馃檪
Bu99ed 路
Had another go at this this weekend and here's what Ive come up with...
Tried putting it in 3rd gear and pushing backwards
Shorting the solenoid on the 2 big bolts works (starter whirrs like crazy)
Shorting the solenoid battery terminal to the small terminal just causes the solenoid to click every now and then(doesn't turn the engine over (is that what it's supposed to do? or should it just click?)).
Turning the ignition key you dont even get a click from the solenoid. (is this a seperate problem as shouldn't I get a click from the solenoid the same as when I shout the spade to the battery terminal?)
Battery charge meter reads 12.5v
So from what you guys have helped me with it sounds like the solenoid is stuffed so Im going to order a new one. Any ideas how long a solenoid swap would take? is it very easy to do with the engine still in?
Paul Aslanides 路
G'day. Suggest you read through a similar thread in this 'Tech Talk' list, re. " Type 2 Starter Problem".
You say that your "charge meter" is reading 13 volts, with the engine off. Any more than 12.8 volts from a new battery is very unusual, imho. Those round - shaped in-dash voltmeters can be wildly optimistic. Mine is a so-called 'reputable' make, but it's about 1.5 volts out. A digital meter from Dick Smith's is far more accurate. And checks lots of other stuff, too.
I dismantled my solenoid too. Didn't find much wrong with it.
Likewise the starter motor. All along it was the battery that was the root of the starting problem. Good leads, with soldered connections, is a great help too.
Good Luck.
mnsKmobi 路
I wouldn't get a solenoid just yet. From what you've said we can eliminate the battery and starter motor from the list of potential causes (b/c shorting the terminals caused the starter motor to go). That leaves the solenoid or the ignition switch and the wires running to and fro. Sounds like it could be both at fault! Shorting the bolt and spade terminal is effectively doing what the ignition switch does, so it should have turned the motor over. From the fact that you don't get a click from the solenoid when you turn the key implies that the electricity is not getting from the ignition switch. You could check that with a multimeter between earth and the lead connected to the spade terminal when someone is turning the key. As for the solenoid, if you can wield a soldering iron you can take them apart and clean the terminals. See http://www.aircooledtech.com/solenoid_repair/ for details.
68AutoBug 路
Yes its a faulty solenoid....
Probably burnt contacts... You pull it apart and clean them or get a replacement starter motor assembly....
Another good [compulsary in MY Book] idea is to have a relay near the battery for the starter motor... then the key switch only activates the relay... no load on the key switch - plus the power goes from the battery to the relay to the starter motor.... MORE power for the solenoid.... Most new cars have this and ALL rear engined cars should have been made with it.... I have My relay mounted close to the starter motor, but near the battery is OK.... still much better than the power going from the battery to the dash and back to the starter motor....
I don't know why You were pushing the car backwards in 3rd gear...
One of the locals started His 200HP Tractor with a screwdriver years ago, the tractor was in gear and went thru part of his house!!!!
Shorting the terminals on the starter motor is very close to a dead short circuit, thats why they can arc.. its like welding....
KruizinKombi 路
Assuming your battery is ok, and your terminals on both the battery are ok:
1) Try running a jumper wire from the battery positive to the spade terminal on the starter. This should start the vehicle if the ignition is switched on. If so, you know the problem is either wiring or the switch itself. If it doesn't, the problem is the starter or solenoid. This is when you try shorting the two nuts on the starter... if the starter turns, it's ok, and therefore the solenoid is the culprit.
2) Find the wire that supplies power to the ignition switch, and the wire that runs from the ignition switch to the starter, and short them together with the ignition on. This should also start the vehicle. If it does, the problem is the switch. Replace it, or put in a temporary push-button. (I did this once and it stayed in for 3 years! 馃榾) If step 2 doesn't work, but step 1 worked, then the problem is wiring...
Bu99ed 路
Got a second hand starter put in last weekend (assumed it was OK). turned the key and didnt even get any lights on the dash come on. Starting to wonder if the battery is stuffed as well... going to buy a battery tester this weekend and check. As my old starter is now out of the van I'm going to get a soldering iron and pull the solenoid appart and clean it up and put the original back in the van... keeping my finguers crossed 馃檪
aggri1 路
I had a similar problem with a 71 Kinga Ute. I cleaned contacts, ran the starter briefly with a spare bit of wire, etc... In the end I borrowed a battery from the VN and it started OK. Strange, because the tip-tray was working just fine, and that runs off the battery.
Maybe try this site for solenoid relay instructions although there was also another great site I saw that gave instructions to do the same thing but I can't remember the site...
Good luck mate.
Bu99ed 路
1 new battery and a cleaned up solenoid later and still no joy 馃檨
the lights are now coming on on the dash and horn and headlights working (Old battery was completely dead). The engines now turning over from shorting out the solenoid. Only thing that is left is the actual ignition switch I think.
I just cant believe that 3 things went wrong at the same time lol
Thanks for all your help and advice 馃檪
General_Failure 路
I know this is a bit late in the thread, but it reminds me so much of what my bloody kombi does. If the terminal connections aren't ABSOLUTELY perfect, I'm lucky if I can even get a click out of the solenoid. When i went to start the engine aftyer the rebuild yesterday, that was exactly what happened.
I like the idea of the relay for the solenoid. I usually put relays on just about everything. never thought of that. how many amps would thr reelay need to be. I have no idea how much the starter solenoid draws.
Bu99ed 路
Hmmm maybe Ill try replacing the spade terminals on the wires that go onto the solenoid...
General_Failure 路
...oops. I meant to say battery terminals. i goofed. Mind you, I have had problems with the wire to the solenoid before.....getting good continuity with the multimeter doesn't mean it's good. All peripherals can work perfectly and the starter can just sit there. If it can't draw enough amps, it does nothing...except possibly make the bottleneck red hot and start melting things....I hate when that happens. I had to bypass the starter solenoid wire on my beetle after a transmission swap. For some rason it went open circuit.
Anyway, just check that all connections are sturdy. And as far as I'm concerned, if in doubt, replace it (especially regarding wires) or at least carry a spare if something still sort of works.
Bu99ed 路
KruizinKombi wrote:2) Find the wire that supplies power to the ignition switch, and the wire that runs from the ignition switch to the starter, and short them together with the ignition on. This should also start the vehicle. If it does, the problem is the switch. Replace it, or put in a temporary push-button. (I did this once and it stayed in for 3 years! 馃榾)
So which one of these puppies is it? and how do I short them together or put a push button on them? I also couldn't see how to get the barrel out (was nice and easy on my split). It all looks like a sealed unit.
Electrics make me feel :puke
General_Failure 路
...so that's what it's meant to look like under there!!!! I'm missing so many parts.
Anyway, the easiest thing to do is to unplug the wires from the steering column. You see how it feeds up to the back of where the ignition barrel is? There's a couple of different modular plugs there. They just unplug, if I remember correctly....I hope I do!!! If I'm right, just get a multimeter or a test lamp, find the +ve connector, and then grab a bit of wire, plug it in, and start striking it against other wires until you (hopefully) find the starter one. I don't know the layout of the plug, and in my experience, colours can vary. Once you have found the starter one, and if the engine cranks (won't start, power only going to starter), tap into the wires, go to supercheap or wherever, and get yourself a starter switch. My soon to be departed beetle has one of them.
mnsKmobi 路
Before putting in a relay or changing the switch you need to be sure that it is the problem. Check if there is +12v from the wire that connects to the spade terminal on the solenoid when someone is turning the ignition key to start. If not then the ignition switch is probably the culprit. I haven't tried replacing it but it looks like a fair bastard of a job so seriously consider the push button approach. The details of replacing the switch are on the following site:
Well I bought myself a multi meter, installed a push button switch and got the van going 馃檪 just took it for a spin round the block.
Just like to thanks to all you guys for all your help and advice :bounce It would have cost me a lot more money without you 馃檪
I still can't believe that 3 things all went wrong at the same time lol
68AutoBug 路
Congratulations... a Job well done....
The weakest link is the key ignition switch... if it had a relay placed near the starter motor in the first place....
You probably wouldn't have had 2 of the problems...
You are never going to get the full power to the solenoid while ever the power has to go from the battery to the ignition switch and back to the starter motor....
A relay would also stop pitting of the contacts inside the ignition switch as a Relay draws a very small amount of current...
Again, congratulations on a fine job....
with 3 different items faulty... an auto electrician would have had problems...
the push button [if heavy duty] will last a long time... and will look cool too.. just like the early VWs....
