car has a 1600 tp out of a type three the bell housing of the 1200 has been ground to fit the twelve volt flywheel. I need to buy a spare clutch. Do I buy a 1600 type 111 clutch or a clucth two suit the 1200 gearbox. IS input shafts the same or not?
you buy a clutch for a 1600, 1200 is smaller in diameter and won't fit the engine. (preasure plate and clutch plate)
Input shaft is the same.
BJ ·
i thought that thanks Craig great appreciated
Brad ·
mmm make sure you take your old 1600 Clutch with you or at least measure it to see if it is 180mm or 200mm it could be either on a 12V flywheel.
