Can some one tell me what keeps the tension on the clutch cable from the peddle end so the cable stays connected. I took the peddle cluster out of the country buggy 9 months ago and don't remember how it goes back in. The book is no help.馃檨
MickH 路
Have you reinstalled the bowden tube?(flexible tube at the gearbox end) The tension of the cable holds it all together and stops it unhooking from the pedal end.
country dubber 路
Yeh, I'v connected it at the gear box end but at the front the peddle can just flop rear ward and then it can disconnect. I think I'm missing either a spring like is on the brake peddle or a stopper.
country dubber 路
MickH 路
From memory there should be a metal lug to stop the pedal falling towards you??
country dubber 路
Thats probably right as I'v bolted a stop bracket on the rear bolt the holds the cluster in place but it's not pretty. If that is the solution then I'l make some thing better.
68AutoBug 路
Yes, there is a plate [used on most VWs] under the pedals that stops the pedals falling towards the rear of the car..
and there should be a spring on the clutch lever [where the cable attaches too]... You can use a longer clutch arm from a super bug to make the clutch pedal easier to push in... more leverage...
