I hope some one can help me .There is an old bug near my house ..going very cheaply ..Its 64 or 68 ish i think ?? Will any of the parts be compatible with my 72 superbug??Is it worth pulling it down to get parts eg engine gearbox etc.etc??
handycam 路
well not realy it s like going backwards in models . The engine if standard will only be a 1500 or 1300 and yours is twin port 1600 and u have irs rear end (gearbox set up) and that 64-68 would be swing axel but ther is a big difrance between 64 -68 6 volt 1300 so on so on if this helps馃檪
MikeM 路
It will have a Link Pin front end and yours is McPherson strut.
There is bugger all in common between the two cars.
Jacko 路
thanks as you have saved me from hours of work on the spanners..cheers.
type82e 路
pass on the location someone else here may be able to use the parts
marcel
