chrome flash clips info?
https://forums.aussieveedubbers.com/threads/25527/chrome-flash-clips-info
type82e ·
I have a 62 beetle with the chrome "flash" I have the clips but not sure if they had the rubber grommets on the body that they went into? the holes they go into arnt as big as the normal chrome trim any ideas
marcel
type82e ·
marcel
The clips depend on the design of the metal trim. I think if its the same cross section as a stock trim them use the origional type clip and rubber grommet to stop water getting into the car.
Are the flash clip made from a wire material ?? I think these were the aussie aftermarket clip.
jnr356 ·
bought my clips from bill thompson antique rubber supplies in ringwood victoria.
they are different to the standard body molding clips.
there are no rubber grommets they just go straight into the drilled holes.yes they are a wire type clip,if you need a sample u2u me
type82e ·
they are the wire clip type so they dont have a rubber grommet? if so waht stops the water getting in and some of the clips are rusty wouldnt that cause the body to rust as well?
marcel
Marcel
check the profile of the trim and if its the same as a stock side trim use the origional VW clips with rubber grommets
Toss the wire ones away. you may have to drill the holes slightly larger.. they made the wire ones as the origional VW ones were not available
new clips are 0.45 cents each.
