Leaving in the Endeavour rally next wednesday and heres a list of spares, any ideas what to take or what not to take?????
Front fuel filter
Pushrod Tubes x 2
Pushrods
Pushrod seals x 4
Short tie rod
Bolts x 2
clutch cable x 1
Accelator cable
King pins and link pins
One set of shocks
alternator
Fuses
Crimp Connectors
Wire Strippers / connectors
Wire
Plugs x 4
Leads x 2
Coil
Coil lead
indicator bulbs x 2
taillight bulvs x 2
headlight bulbs x 2
h1 spotlight bulbs x 2
spark plug hose
Cable ties
jumper leads
electrical wire
Alternator belt
Duct tape
Complete distrubator
tire plug kit
Points
Fan belt
Left front spindle (they're weak due to speedo hole)
Speedo cable
- Assorted nut and bolts to suit car
Spare wheel studs
Tie wire
INOX
Ether
Tyre Shine
Degreaser
Brake Fluid
Ultra Blue
Loctite
Hand cleaner
Ultra Red
Wheel Bearing Grease
Window cleaner
Brake cleaner
Schokies front x 2
Wheel Studs x 8
Alternator
Torch
32 mm socket
36mm socket
Extension for above
Breaker bar
Socket set ¼ or ½
2 sets of metric ring or openers spanners
various size shifters x 3
allen keys
pliers pointy noise flat and fencing
claw hammer
tyre repair gear
mirror
brak adjuster scredriver
screwdrivers
wheel brace
funnel
shipon hose
multigrips
manual
Jack
Compressor
Tie wire
Oil
Alternator belt
Clutch plate and pressure plate
Fuel line
Rags
Brake hoses
Knead it
Paper towel
1 Set of shocks
LH Lower Control Arm
LH Upper Control Arm
LH Spindle inc. King, Link Pins and attaching hardware
Rh Lower Control Arm
RH Upper Control Arm
RH spindle inc King, link pins and attaching hardware
Pushrod Tubes x 2
Rear fuel filters 1 set of two filters
Engine gasket kit
Engine seal kit
Exhaust manifold kit x 4
Intake manifold gaskets x 4
Axle nuts x 2
Rear transmission mounts x 2
Front transmission mount
Clutch Plate and pressure plate
Starter motor
Trannie
Rear torsion bars
Clutch cable hook
axle & boot
Spring plates
BJ ·
