how low is too low? (Legally)
https://forums.aussieveedubbers.com/threads/25713/how-low-is-too-low-legally
Golde60 ·
Just wondering what the law states (in Vic) for height.
i beleive it is something along the lines of :
"any part of the body or suspension not less than.............?"
can anyone fill in the blanks?
90mm ? 130mm?
everyone seems to "know" but i want to K N O W!:thumb
barls ·
100mm by the adr's which all states laws are roughly based on but check with vic road to be sure
Adam_C ·
yeh i was tool 100mm, but i think thats the chassis, the body may be lower...... am i wrong? or right? ive allways wondered?
barls ·
it usually measured to the lowest point
VWFOOL ·
yeh i rang RTA tech guys the other day to make sure and it was 100mm, lowest point of the car
Adam_C ·
ah ok kool
wrecker67 ·
bump stops is about it then......:jesus
Flintstones ·
technically it's 125mm (5" in the old money) and with 20% loading, it becomes 100mm and that's measured at the lowest part of the car
[Edited on 8-7-2004 by Flintstones]
HotRodMatt ·
Technically, it's 100mm only if approved by an engineer.
Legally, without an engineer's certificate you can only lower to 1/3 of the suspension travel. eg. if you have stock 6" of suspension travel, you can lower 2".
[Edited on 8-7-2004 by HotRodMatt]
I read somewhere on the Vicroads website in the vehicle schedules that brake backing plates are not included in the measurement.
MikeM ·
The following is an extract from:
http://www.transport.qld.gov.au/qt/driver.nsf/files/images/$file/Vehicle-Modifications.pdf
which can be found here:
http://www.transport.qld.gov.au/qt/driver.nsf/index/vehiclemods
here is the extract:
Lowering or Raising of Vehicles
The road clearance of a motor car must not be less than 100mm
measured at any part of the vehicle other than the wheel rim
or brake backing plates. (This does not apply where a lesser
clearance has been specified by the manufacturer.)
When lowering or raising a vehicle body (front or rear):
• the suspension travel in the bump or rebound mode must
not be altered by more than one-third of that specified
by the manufacturer;
• coil springs are to remain in locating seats on full
suspension droop without forcibly being removed.
In addition, the normal relationship between the front
and rear suspension heights must not be unduly affected.
Suspension coil springs must not be shortened by cutting.
Leaf spring suspensions must not be raised by the use of
extended shackles or adjustable metal plates. If lowering
blocks are used, they must be either steel or aluminium.
[Edited on 9-7-2004 by MikeM]
twoguns ·
always thought taht is was when you lowered the car after doing the mods, and you CANT GET TEH FRIGGIN JACK OUT!... thats neville front on.
