5 speed?
https://forums.aussieveedubbers.com/threads/25824/5-speed
71superbug ·
hmm. i was wondering is it possible to convert a vw box to 5 speed?. or wat is a cheap 5 speed box that can be used?.
thanks
anthony.
71superbug ·
and also. is it possible to use a mazda mr2 transmission.? and maybe even engine? because they have rear mounted engines also.
[Edited on 11-7-2004 by 71superbug]
5 speed and CHEAP are not in the same sentence. !!!
Have not seen and other makes of gearbpx used in a street VW. Y?Ou could adapt in a buggy where you have more room
barls ·
gene berg make the only 5 speed i know of and it requires a bit of pannel work to fit it in check his site for more info.
BiX ·
i thnk some of the buggy boys were looking into the reanault 5 speed box. But to get a 5 speed transaxle in you will require major work, from a porche or a full racing box, it will be alot of custom afbrication work. Is the mrs east west or north south engined? you migh find alot of the mid engined (not rear as in beetle) will have a similar setup to a front engined car (eg east west engine) but which has been mounted at the back. On option that may be work investigating is using a north south 4wd gearbox, eg wrx, as these i believe may have the outout shafts for the front at the side so of the box, but you would still have to flip the box over and again ist alot of custom fab work.
Anthiron ·
MR2 engines are mid mounted and rear wheel drive arent they.....might be an interesting conversion though i have never heard of it being done and i doubt it would work well. anything is possible if u have the money. if you are worried about your ratios and having the extra gearing of a 5 speed....get your box rebuilt with the ratios you want for highway driving or whatever. it will be cheaper and easier.
barls ·
with the 5 speed kit you get a new 4th and 5th but its about a grand to bring one in last time i looked but there are some out there in the trading post there is a 1500 with one for a grand but its been in there for a while
Che Castro ·
here's a guide to putting a porker 5 speed
http://www.germanlook.com/Html/Tech/Tech02Porsche5SpeedTrans.htm
BiX ·
I have seen a camira motor placed in the rear of a honda city. It was a very fast track car. basically just cut the front end, (engine, gb and suspension) out the camira and welded it into the honda witha roll cage.
barls ·
just remember that no matter what you do if it modified it may need a engineers for it or your insurance will wipe it if any thing happens
BiX ·
yep well anthiron, i think the MR2 is east west layout and therefore the gb wouldn't fit. one option is if you want a nice short circit setup, go a low third but stock 4th that way you have a close 1,2,3 for race up to about 140 ish km/hr but the normal highway ratio?
71superbug ·
yeah i was thinking a Liberty RS box. as this is the engine which i would use for a conversion eventually. the liberty used a variant of the EJ20T. it is same engine. just slightly diff heads i believe. still 147kw (197hp). and i can only find them in bloody half cuts. 🙁. anyone have input on this. how would a 4wd box go with a non 4wd car?. and also is the 5 speed kit worth getting?. i have at the moment 1200 to spend. looking at spening about 1500 in this chunk on my car. eventually looking to build a real performance street car. do u think i should spend the money making my engine more powerful. or maybe a pedders sports ryder suspension setup?
Che Castro ·
If you are only intending to build a 1776 engine i'd spend the money on setting up the chassis properly. Upgrade the suspension, steering, brakes, get it all tight. I think this would be the most bang for your buck in the overall scheme of things.
A 5 speed box should probably be the last thing on your list, not many ppl do it because it is difficult and expensive - its a bit of a luxury item. The 4 speed box is fine if your engine is flexible enough.
BiX ·
what castro said. well setup suspension will be more of a improvement, than the extra close ration of a 5 speed box.
barls ·
that and a good shifter classic has the empi trigger shifter on special at $100. dont forget the strut tower brace its important. im not 100% sure if anyone in this country is carribg them but a silva one fit the ends just need to be adjusted( read shortened with a hacksaw) and it fits perfectly. got one in my sbug down stairs
Che Castro ·
hehe i'm a fan of the stock shifter myself, with urethane couplers and a new shift rod hanger bush with a quick shift kit. Nice and tight - a bit notchy though, although better than a lot of modern cars 🙂
you can make your own strut brace pretty easily if u can weld out of some box section steel.
Secoh ·
renault box requires floor modifications.
subaru boxes from liberty, RX and WRX CANNOT have the diff flipped so you'd have 5 reverse and 1 fwd gear.
Caravelle 5sp will fit wit no more mods than a kombi box BUT the ratios are all wrong and 5th is still more or less 1:1 ratio, and they are weak as cheese apparently.
your options for minimal mods are (as far as I can see) gene berg kit, or porsche, but both will cost the equivalent of the Chinese national debt. 🙂
