Does anyone out there know what position these switches need to be in to work on a 4 cylinder engine?
I think it is set for a V8 @ the moment
lobus ·
Front view
blutopless2 ·
hahaha... i thought that's what you had in lobus after the pic of the speedo!!! :thumb
i take it you dont have the manual??
nothing marked on the back??
have you tried changing them to see what happens??
i'm done...
lobus ·
nah the one in me bus isn't a VDO
no mate, no manual
nothing on the back
I's not hooked up to try the multiple choice option
but that gives me somethin else to do.
now I'm done
barls ·
ill check on the one out of my other sbug, ill get back to you
blutopless2 ·
does it have any serial numbers or model numbers on it?? then you could do a search on the net for info on it
barls ·
i dont think this will help you cause mine only has 3 switches and its left to right the switches go up,up down. i suggest contacting vdo for the set up of the switches, their site is www.vdo.com.au
good luck mate
*did* ·
I've got that tacho, hopefully will get a pic for you when I get some time.
lobus ·
Thanks for all the tips volks I'll pull it apart and see what I can see this time..
I have two of these, not installed as yet..
Came from Beetles and the 4 is Down.....
