Is it starving for air?
https://forums.aussieveedubbers.com/threads/2610/is-it-starving-for-air
karmannghia60 ·
I had one of those mushrom air filters in the garage which was missing the element so I some foam to size but now @ around 2800 rpms and under pressure, the engine just dies (loses all power). If I easy my foot of the accelator, it pulls again. Is it because the foam is too dense and not letting enough air through when needed?
Raf
Grey 57 ·
Raf , take the foam out and see if it still does it.
If the foam was restricting it that badly it would probably suck it down the carbie.
karmannghia60 ·
Took the foam out last night. Worked OK this morning. Gotta get the right filter then
70AutoStik ·
You can actually buy air filter foam, but you end up with more than you need (I still have about a square metre left from some I bought about 8 years ago, but it's starting to break up now...)
