a question about the coil
https://forums.aussieveedubbers.com/threads/26276/a-question-about-the-coil
bigbruvabob ·
hi guys am going to change the coil over on andreas roadster to a gt 40 that i have but my problem is the coil on the car is not marked with +ve or -ve. Can someone please confirm that power from ignition goes to +ve and -ve goes to distributor. Cheers david
Madeline ·
Just buy a new one that IS marked.
karmannghia60 ·
Hey Dave, yes -ve to distibutor and +ve to loom
A coil will work either way round....
although Not as well, when its around the wrong way...
and it can cause problems...
Positive + Power to the coil +
Negative - to the points & condenser.
toplessbug ·
make shure its a gt40 not a gt40R as the R model is designed to work with a ballast resistor and will quickly destroy your points if you use it
bigbruvabob ·
yes lee thank you i believe that this is the problem with the coil on there at the moment.As when i hook up my dwell meter to what should be +ve it nothing happens but when i hook it up to what should be -ve i get reading. this is the reason i want to change the coil over as it is getting me confused.
bigbruvabob ·
bigbruvabob ·
bigbruvabob ·
*did* ·
has anyone tried the gt40t (transistor) coil? according to the packaging these are better at operating through high heat and vibrations. i'm thinking i might try one.
