Morning all,
Over the last few days I've been greeted with a continuously blowing fuse, running the driver-side parkers (headlight, tail light, numberplate light). At roughly the same time the drivers indicators have also been playing up, rear one not functioning and front one going twice the pace.
I was treating it as 2 separate problems, the indicator bulb seemed to be loose and with a finger touch it would work. Later it would loosen and stop again.
Been cleaning connections for the other light problems, would go OK for a while then blow again. Scratching my head I was.....
Last night, with the indicator again playing up, took it all apart and made the bulb cavity a bit tighter, meaning the bulb now can't wobble around at all, making bad connection. Seems to have fixed the indicator....and the lights!
We're talking the same side here - drivers parkers and drivers rear indicator. Is there a possibility - and I'd like frank advice here - that the wobbly bad connecting bulb in the indicator was playing havoc with the tail light and causing the parking lights to blow?
I'm hoping someone says 'yes' truthfully cause I'm sick of pulling the lights apart.....
phantom ·
