anyone know about auto\'s?
https://forums.aussieveedubbers.com/threads/26308/anyone-know-about-autos
RISKY^VW ·
hi gang
wanted to know about this auto as i have never seen one
the holes around the out side look like they should be the but what a bout the one at the bottem?
11CAB ·
If you are talking about the holes in the bell housing, they are for cooling the Torque converter
RISKY^VW ·
even the one in the bottem ?
looked like it had been broken from my first look but didn't have a close look
seagull ·
yes I am your man , what would you like to know .and what are you doing with this any way ?
seagull ·
itys a 003 auto as well , dont lose the bits .
Midlife crisis ·
The one in the bottom is doing up the nuts that join the convertor and the flex plate to gether.
Marc
RISKY^VW ·
ahhh thanks 🙂
and to seagull the bits i think your talking about i don't have 🙁
seagull ·
o shit what a loss !
The cut out on the bottom of bell housing is to allow access for your finger and to do up the 3 bolts that attach the drive plate to the torque converter.
the engine crankcase also has a similar indent to allow access.
If your not using the correct engine casing then its going to be very hard to do up the 3 bolts. not much room in there.
