1300 cases gasket question ??
https://forums.aussieveedubbers.com/threads/26350/1300-cases-gasket-question
seagull ·
I rebuilding a 1300 cc case ,looking the the 6 of 12mm case bolts there is no taper at the base of the case for the O ring to sit in , this is the seal to stop oil going up the case bolts .
was this a change made to cases later on ?
ideas
seagull ·
must be a hard one me think !
It was a later innovation, just make sure you put some sealant on the nuts. A man with your talent be able to retrofit.
1302Steve
seagull ·
Yes I counter sunk some O ring groves steve , should be good for 30 years more running .
lots of small changes over the years , making things better .
Che Castro ·
a little dab of sealant on the washer and nut works well. Just make sure it isnt the type that goes hard
I always use Curil in cases like this.
1302Steve
