Hi Joel,
Not sure on the Type 3's but on the twin Solex Kombi's the hot idle valve (the one mounted on the throttle body below the carb itself) was installed on Auto's only and opened and extra jet (allowing more fuel in) for a faster idle when cold to prevent stalling, so I guess you can blank it of OK if doesn't stall when cold. Similarly there is an 'idle mixture enrichment' (next to the central idle adjustment) which also increases fuel when cold, and shuts off when heated by a resistor. All the ones I've seen have rattled to pieces and I haven't been albe to find a replacement. I have blanked mine off with no ill effects if the chokes function correctly. I believe they are mostly usefull in very cold climates!
Andy.
Andy ·
