Anyone know what the upper reat seat mounts for a '74 Double Cab ute should look like as mine are missing and I need to get some asap.
Is my first time on this so hopefully someone will know. I am based in NSW
Look forward to hearing from you
11CAB ·
The upper mount is like a hook mounted the the back wall, the back part of the seat a rod running through it so that it hinges up to allow the bottom part to hinge as well to gain access to the storage area underneath
Skywalker ·
Cheers for the info - mine also has bars sticking out of the bottom of the top part - should there be brackets at the bottom too?
tracash242 ·
the bottom seat sits on a metal u shaped peice that comes out with butterfly nuts,and it has the brackets joined to the top of that that,like the brackets up top,2 peice seats that come out,with the third peice being the metal u shaped bit that supports the bottom seat,
Skywalker ·
Sorry - seem to have caused some confusion - talking just about the top half of the rear seat - there is the bar that goes all the way across the top that goes in the brackets, and there is also a bar/ peg, near the bottom of the top half of the seat, on both sides - are these meant to have brackets too?
I am missing all of the mountings for the top half od the rear seat - anyone know where you can buy them?
