help neded, URGENTLY!!!!!!!!!!!!!
https://forums.aussieveedubbers.com/threads/26599/help-neded-urgently
General_Failure ·
Hi all,
I'm in a bit of trouble!!!
My 1800 van is running like a one-legged dog.
Everything was okay until about 5km from home yesterday.
The car lost power and kind of limped home.
Today it started first go, was revving fine, but it was 100% gutless. As soon as i tried to move it in gear...bleh. Engine struggled and died.
Did a LOT of tampering today trying to get it working again. Replaced the fuel pump with an electric, because I didn't trust the mech pump. Now it didn't want to run at all.
Checked the carbies, the left one's float decided to jam. Unjammed it.
Replaced a couple of wiring connectors, even tried hotwiring the coil. Still almost impossible to start, sounds like it's running on 2 cylinders, and need my foot on the accelerator to keep it running.
I still suspect the left carby (the idle one), and am hoping it has nothing to do with the topend rebuild I did.
Also considering maybe there's a leak between the head and inlet manifold. The studs were pulled on the head I put on (didn't realise until it was too late).
Anyway, What's wrong with my van!!!! I'm moving interstate on saturday!!!!
t2 ·
did you adjust or check the tapets ,i had a bay do the same thing and it was a burnt out valve. but i am no expert so could be wrong
General_Failure ·
i did them when i put the motor back in. and it hasn't even done 100km since.
also, it came on suddenly.
I dont know what it is!!
General_Failure ·
...oh yeah, the rocker clearances still seem fine, and there are no major oil leaks, so I guess the head studs haven't pulled
General_Failure ·
Update....
Have to sell the bug now 🙁 And the van is going into storage.
I think it broke a &*^(&%(^ ring. There's a 'squeak, squeak, squeak' coming from no. 3 cylinder, and the car can barely move under its own power.
I also have to sell my nice 4wd enclosed trailer that the kombi tows (no more space in the container)
Tristan.
barls ·
it sounds like you need a few things there mate. first a hug, second a jerry can of fuel, and some matches. * hands items over* now play nice 😉😉😉
aggri1 ·
Look barls, you sound like a perfectly rational human at most times, but if you're suggesting violent actions against a kombi, there'll be trouble! I take it you weren't suggesting what I think you were.😠
I have an 1800, and it plays up too. Has been doing so for months, and no-one knows what the problem is. Every time I get fuel, after having driven for a while, and at other random occasions. I can't figure it out for the life of me!
I found that if I switched the engine off while driving, upon restarting it the problem (power loss) went away. Sometimes required several restarts. However, your problem sounds rather more severe. Good luck, hope the move goes fine too.
barls ·
aggri1 wrote:Look barls, you sound like a perfectly rational human at most times, but if you're suggesting violent actions against a kombi, there'll be trouble! I take it you weren't suggesting what I think you were.😠
no thats not what i was suggesting cause if i was it would have been c4 or ampho. i just thought that id play on his mood. no vw is without problems. my baby has broken down on me a couple of times, on the highway and on a busy sydney road at peak hour, but it is always loved and cared for.
aggri1 ·
Oh that's nice.
barls ·
im sorry i just miss the boys at work ive been away too long on a tax payer funded holiday(sick leave)
General_Failure ·
yes...burn...BURN!!!!! Burn the damned ones!!! hAHAHahAhahaHaHahA!!!!
Anyhow, the van's in position to go into the container now. Such a pity. So much work. Failure. Again.
I think I'll just put in a 2L with the 1.8 flywheel on it after we move...or A subie motor, or something. That engine disgusts me. As long as I don't take my foot of the throttle it blats away happily on the 2 or 3 cylinders that are working, while emitting the bone-shattering squeak from it's innards.
On the bright side, for the first time since I got it, the heater works. Go the foam mattress and coke cans!!!!! The dual battery system also is very handy for a flat battery. Just need to leave the ignition on for a few minutes and the primary battery is charged enough for some more cranking.
Anyhow, this whole situation reeks. I don't wanna sell my bug!!!!!
The bug may be a bit battered, but it never fails to run. The van on the other hand.....I think I used to have at least one breakdown a week. Like when the output pipe on the fuel pump came adrift...or when that stupid clamp for the throttle cable came adrift uphill on an intersection....or when the valve seat went byebye in the middle of nowhere...I could go on for hours, but I'd probably go insane.
...maybe next time a nice V6 or uhhh...something cheap. Yeah!
