This is my engine in my kombi. I am not really sure what it is. All i was told is that it is a 1600 ti! what is the ti bit? and is there anything else special or notable about it? Twin or ...
Thanks everyone
HotRodMatt ·
TP not TI.
Twin port. Standard kombi engine...
Just the air-cleaner has been changed from the horrible massive old oil bath jobbies
barls ·
it looks like a twin port but hard to tell for this angle what do the manifold ends look like? if they are are a narrow and one pipe its a single but if its got a notch in the middle it a twin.
Grock ·
Right, not sure, cant check now either, But if thats how you tell i think i'm pretty set now... thanks.
HotRodMatt ·
Single port manifolds look considerably different. They are twin port manifolds .
Che Castro ·
yep looks like a twin port. from what I know single ports had a one piece manifold rather than end castings and rubber bits.
Doug Sweetman ·
Whats special about it ?
Chrome tinware !
Degreed aluminium pulley !!
Shiny aftermarket air filter 🙂 !
Aftermarket Bosch ignition coil
Alternator too if I'm not mistaken.....
Looks like a nice tidy engine.
Che Castro ·
yeah looks tidy. alternator with alternator fuel pump. That GT40 coil isnt much different from a normal one. i got one too!
nbturbo ·
If it's the original engine for the vehicle it's a 1600 twin port.Must be a late model because it has a booster for the brakes.Put some caps over those fresh air outlets on your fan housing-you will need all that wasted air when the weather warms up.
Grock ·
Got down to see the kombi this weekend and took it for a nice scenic drive. Feel like i've had a weekend now.
nbturbo wrote:Put some caps over those fresh air outlets on your fan housing-you will need all that wasted air when the weather warms up.
Not sure what you mean about that, sorry. Borrowed a digi cam so got a couple of other pics. Runs a real treat. Starts no worries even though it has not had much attention at all for about a month (unfortunately).
Grock ·
Hmm, pics not working not sure why! will try later.
karmannghia60 ·
Has an alternator and an oil temp sender. What's the vacuum hose coming out of the manifolds for?
Raf
