Aussieveedubbers 路 Tech Mods and Frequently asked Questions
PLEASE HELP!!!! lowering my beetle
https://forums.aussieveedubbers.com/threads/26703/please-help-lowering-my-beetle
Ross 路
Ha all
I have just lowered the rear of my 61 beetle another inner notch (it was lowered one notch when i bought it) to find that it now makes an awful sound in the rear like it's bumping out, i left the rear bump stops out.
My question is... if i place the inner spline to the original position (stock height) and then adjust the OUTER spline to lower it....will this fix the problem?????
I have done this mod so many times and never come accross this problem!!!
[Edited on 31-7-2004 by Ross]
Desert Moose 路
Ross wrote:Ha all
Well I can't tell you if it will work and stop bottoming out but this should help you.馃檪
If you torsion bar standard springrate with 40/44 spline turn the inner and the change is 9deg turn the s/plate and you get 8deg 10". so turn them both in opposite directions for increment angles. but before you do this go to bunnings or somewhere and get a degree measuring tool (mine only cost $10). this tool will make sure you have the right preload on each side by measuring the s/plate before you jack it into place.馃槑:thumb
:bounce
Ross 路
What the????
Thats more complicated than my uni degree!!!!!
type82e 路
I just use a cheap plastic protractor(I think thats waht theyre called?) you can get them at a newsagent fro about 50c to measure the angle between the plate and the shock tower its pretty accurate
marcel
Desert Moose 路
Ross wrote:What the????
lol....... it's not that hard.
think about it, one end has 40 splines and the other has 44. :thumb:thumb:thumb
Desert Moose 路
look at it this way it's only moving 10% of one inside spline........lol
