Aussieveedubbers 路 Offroad V-Dubs
Bearings for buggys
https://forums.aussieveedubbers.com/threads/26828/bearings-for-buggys
Desert Moose 路
I think it was Mick M that was lookin' for this info馃槈
Rear stub axle bearings part No. 63007 is 62x35x20mm
if it was you Mick' I hope it helps you
Moose
MikeM 路
Thanks..... but
The 63007 is a 20mm wide bearing?
63007 on SKF
The standard bearing is only 16mm wide so how does this fit in a standard beetle arm?
6206 on SKF
I don't see how the bearing 63007 could work? The original post you mentioned this in you alluded to the fact they were taper bearings? The 63007 is a deep groove ball bearing? Maybe the part number mentioned here is wrong and it should be a taper roller?
Or maybe the Type1 arm needs to be machined 4mm to take this bearing?
There is a taper roller that is 35x62x18 with a housing (C) of 14 that you could use with two circlips as the circlips are 2mm thick. One circlip to lock, one to space. Maybe this is the bearing you used?
32007 on SKF
I don't know I'm just guessing?
Can you give me any more details?
Thanks.
[Edited on 4-8-2004 by MikeM]
Desert Moose 路
Sorry mate your right wrong part No..... I just got the number off an invoice (the 20mm is if you use long kombi axles and is not what you want). The 32007 is the one give me a buzz and I'll tell you how to set it up.
Moose
0429 937 906
