How a carburetor works
https://forums.aussieveedubbers.com/threads/26934/how-a-carburetor-works
Gibbo ·
I ask because, although the older guys are familiar with these things, I would imagine that some of the younger / newer guys may well benefit from a little refresher on basic carburetor function. Having a more in-depth understanding of the basics of carb design and function will likely make it far easier to get them set up correctly.
The basic secret of carb function is that inside each carb are thousands of tiny gnomes; each with a small bucket. As you open the throttle, more of these gnomes are allowed out of their house and into the float bowl, where they fill the buckets and climb up the carb's passages to the intake, where they empty their buckets into the air stream.
But, if you don't run your bug for a while, bad things can happen.
Tiny bats take up residence in the chambers of the carb, and before long the passages are plugged up with guano. This creates a gnome traffic jam, and so not enough bucketfuls of fuel can get to the engine. If it gets bad enough, the gnomes simply give up and go take a nap. The engine won't run at all at this point. Sometimes you'll have a single dedicated gnome still on the job, which is why the bug will occasionally fire as the gnome tosses his lone bucket load down the intake.
There has been some research into using tiny dwarves in modern carbs.
The advantage is that unlike gnomes, dwarves are miners and can often re-open a clogged passage. Unfortunately, dwarves have a natural fear of earthquakes, as any miner should. In recent tests, the engine vibrations caused the dwarves to evacuate the Harley Davidson test vehicle and make a beeline for the nearest BMW dealership. Sadly, BMW's are fuel injected and so the poor dwarves met an unfortunate end in the rollers of a Bosch fuel pump.
Other carb problems can also occur. If the level of fuel in the float bowl rises too high, it will wipe out the Section 8 gnome housing in the lower parts of the carb. The more affluent gnomes build their homes in the diaphragm chamber, and so are unaffected. This is why the bug is said to be "running rich".
If the fuel bowl level drops, then the gnomes have to walk farther to get a bucketful of fuel. This means less fuel gets to the engine.
because the gnomes get quite a workout from this additional distance, this condition is known as "running lean".
The use of the device known only as the 'choke' has finally been banned by PETG (People for the Ethical Treatment of Gnomes) and replaced by a new carb circuit that simply allows more gnomes to carry fuel at once when the engine needs to start or warm up. In the interests of decorum, I prefer not to explain how the 'choke'
operated. You would rather not know anyway.
So, that's how a carburetor works.
barls ·
good one gibbo. hows the searching for a pan going mate?
pyr0 ·
LMAO i knew there was some thing funny going on in there :bounce
Gibbo ·
barls, not much showing itself, pain in the arse, oh well, keeping on keeping on....
barls ·
it took 4 months of searching for my bug body and now that i found one they are coming out of the woodwork. just dont give up and you will find one
Gibbo,
Well You got one thing correct....
if You leave fuel in the carburetor for a long time...
it turns into gunk and clogs up everything including the accelerator pump, which is near impossible to clear as there is a ball bearing in an unaccessible place... which jams up--
so No accelerator pump - means the carby won't work...
I will be surprised if the Newcomer can understand Your description of how a carburetor works... It mostly made sense to me... but then I've been around for a long time...
$2.63 homebrand baja ·
RACQ guy looks in confused amazement at $2 as she explains problem:
"well u see this gibbo guy on forum posted about the gnomes in the carbi. I thought it was running a bit lean so I shoved a vegimite sanga and a cuppa tea down barrel, caus i thought they might be hungry..."
dats funny gibbo!:P
tassupervee ·
The answer to the heading of the original post: How A Carburettor Works:...???
'Cause it just does!
L8tr
E
