can i ????
https://forums.aussieveedubbers.com/threads/27041/can-i
kodok ·
i have a 1954 oval beetle, unfortunately something wrong with the engine so i am planning to put bigger engine into it.
is it possible to put fastback engine into my betle ? will there a lot of modification ?
thanks
hendra
barls ·
only an upright conversion kit but if you go over 15% of standard you need an engineers
karmannghia60 ·
All T3s had 1500 or 1600 engines which are wider than the 40hp. I thought you need to do some engine bay clearance to fit the wider engine in an Oval bay?
baybuscamperkid ·
if you were going to do that you may as well go al the way and use a bay kombi t4 2l, would cost about the same.
Anthiron ·
i agree with baybuscamperkid. i suppose the only reason u are asking this question is because u have a Type 3 engine that u could use however if u are going to go to all the trouble then u may as well get a nice big fast donl to power your oval. besides the ricers wont know what hit them when u dust em off at the lights😎
karmannghia60 ·
T4 swap cost about the same??? I don't think so and it is much more complicated. You are up for a minimum of $780 for the upright conversion kit (talk to Sharp Build) then preferably you will have to fabricate a rear engine mount because the T4 engine is heavier than the T1/T3 ones. Then there is teh fuel pump that you have to do something about too. I agree you would get more power but not for the swap price or amount of effort.
barls ·
i dont run a rear mount and use a electric pump. it cost me $2G with engineers
