can you acid wash ???
https://forums.aussieveedubbers.com/threads/27238/can-you-acid-wash
wacked1 ·
an engine. I'm only wanting to clean the exterior of the engine with HCL so i can paint it and get rid of old oil and muck.
has anyone done it at home with Hydrochloric acid HCL
thanks
ron
lil dub ·
wacked1 wrote:an engine.
yeah yeah ron....we all know your secret addiction to acid wash denim....no need to hide...you're amongst friends.....!
aggri1 ·
Hmm, acid and aluminium will make a nice explosive gas. Don't use the acid too concentrated (der!).
Uh, I don't know man, is it a really important engine? I'd make sure I didn't get any inside 'n' stuff.
Adam_C ·
becareful..... is it a case with magnesium in it..... if i remember correctly Hydrocloric acid and magnesium = Hydrogen = BOOM
You would be better off wiping it down with a solution of Caustic or Baking soda from the kitchen but wash it off good as it keeps on working
Anthiron ·
sodium hydroxide + Aluminium = hydrogen also........i would be very careful doing this. if do go ahead with it i would do it in a very well ventilated area. hydrogen is fine as long as there is no ignition.......its the ignition thats the problem lol:P
Why do you want to paint the engine case ///// it will only keep the heat in and not allow it to cool properly.
Clean all the crud off yes but dont paint the case.
wacked1 ·
sorry guys this is for the iron block v8
Adam_C ·
hmm cast iron, the acid will still etch into it, try kero and scrubbin brish.... but i wouldnt use acid...... cheers
pod ·
yeah ,elbow grease ,a big bucket of kero and a scrubbin brish :P
sorry adz couldn`t help having a dig at spelling:thumb
pyr0 ·
or metho 🙂 i think id use the kero but...only cause ive seen other people do it and it came out good
baybuscamperkid ·
some good degreaser should do the trick. the stuff from clints had 30years of grease runnign off my old kombi donk.
Adam_C ·
hey Pod....... (INSERT MIDDLE FINGER GRAPHIC HERE) it must be my mangled fingers, my typin is terrible...... damn wicketkeeping/ AFL hands lol
pod ·
raflmao
get the iron block sand blasted
~air fooled~ ·
harness the power of flammables and burn the s#it off!!!! whoosh!!! do it like the kombi on fire in chit chat section!!!! go out in style man hhahahaha :P:P😉
