Offsets
https://forums.aussieveedubbers.com/threads/27302/offsets
robroy ·
Hi all
Can someone explain the offsets of mag wheels?
Will a 5.5x15 empi fit on a splitty.
what are 112 pcd and 130 pcd's
thanks
barls ·
5.5 is the rim width, 15 is the mag size, and the pcd is the offset distance between the studs
Dasdubber ·
15 in is diameter
5.5 width as stated
pcd = pitch circle diameter which means the diameter of the circle which would be theoretically drawn through the studs (5x205 = 5 stud at 205mm [early vw/porsche]; 5x130 = 5 stud at 130mm [porsche])
http://www.tirerack.com/wheels/tech/offset.htm
http://toy4two.home.mindspring.com/offset.html
http://www.usacomp.com/Offset.htm
Try popping in "wheel offset" into google.com or similar search engine for heaps more info.
robroy ·
thanks
so do 130 x 4 stud only fit porches.
112 x 5 fits bay kombis but do they fit anything else
what wheel pattern fits a beetle then
robroy ·
and forgot something
4.5" 5.5" wheels will these fit all models without adapting or shortening the beam
Unity-28 ·
130 4 stud PCD will fit any 4 stud VW and 4 stud Porsche. 112 will fit some Mercedes, and 4.5 and 5.5 will fit on a beetle without narrowing the beam, unless the wrong OFFSET wheels are used.
N!
