I have a whole heap of VW Trends tech articles as pdf if anyone is interested in them. They are 21MB in total, and I can put them up on my website tonight as a 21MB zip file.
If your interested in any of them individually then send me your email in a U2U and I will mail it off.
They are:-
20 Transaxle Upgrades.pdf
36hp Dyno Shootout.pdf
36hp Tune Up.pdf
37 Essential Tools.pdf
50 nifty Accessories.pdf
50 parts under $50.pdf
Aluminum Bumper Install.pdf
Berg HArd Start Solenoid.pdf
Billet Monster Motor.pdf
Blocking Out the Body.pdf
Brake Resto.pdf
Buggy - Shortening the Pan.pdf
Bus Freeway Flyer.pdf
Bus Master Cylinder Replacement.pdf
Case Machining & Prep.pdf
Caster Shim Install.pdf
Cheap Tricks.pdf
Cleaning Inner Fender.pdf
Coaxing a Car from Cocoon-Brakes.pdf
Convert to IRS.pdf
Cylinder Head Shootout 2.pdf
Cylinder Head Shootout.pdf
Cylinder Heads.pdf
Decklid Hinge Repair.pdf
Door Assembly Resto.pdf
Door Hinge R&R.pdf
Drop It + Stop It.pdf
Final Body + Paint.pdf
Floorpan Replacement.pdf
Front Apron Install.pdf
Gene Berg Heater Boxes.pdf
Gettting Wired.pdf
Handy Technical Specifications.pdf
Heater Channel Replacement.pdf
Ignition Beyond 009.pdf
Ignition Timing 009.pdf
Ignition Timing Beyond 009 Part1.pdf
Interior Re-do.pdf
Lifting the Cam.pdf
Long Block Assembly.pdf
Mag Wheel Polishing.pdf
Make your Vw Dent Free.pdf
Match Porting.pdf
Narrowed Front Beam.pdf
New 911 Fanshroud.pdf
Nitrous install part1.pdf
Nitrous Installation.pdf
Painting Plastic + Fibre Glass.pdf
POR-20 Surface Protection.pdf
POR15 Floorpan.pdf
Pre Travel Checklist.pdf
Raising the Rear.pdf
Rear pop-outs.pdf
Release Bearing Tip.pdf
Replacing 69-79 Bumpers.pdf
Replacing Axle Boots.pdf
Replacing Cracked Boots.pdf
Resto Checklist.pdf
So Cal Imports VW Trends Mail-Order Resto-Custom, Part 8.pdf
Speedo Resto.pdf
Stopping Slippage.pdf
Swapmeet Guide.pdf
The Distributor of Power.pdf
Timing from the Drivers Seat.pdf
TMI Bus Interior.pdf
Transaxle R+R.pdf
Type 3 Rear Drums.pdf
Tyres 3 Easy Lessons.pdf
Valve Adjustment.pdf
Vent Wing R&R.pdf
matara ·
