Blue dots???
https://forums.aussieveedubbers.com/threads/27440/blue-dots
robnjo ·
always been a big lover of the blue dots but have never got any for my cars in the past.
which ones are the best- glass or plastic or doesn't it realy matter?
and where is the best spot for them - tail or stop lights?
now I do run the U.S spec tail lights on my sBug (illegal QLD yes?!? but they have been on my car for 3.5 years now and have been pulled over a few times no problems)
.....maybe I could try them in the red indicator??
any way what do you know??
Rob
Adam_C ·
theyre illegal.....i have em ..... glass is better..... to install em take a socket the same size as the actual dot not the bezel, mark the spot to put it and then heat the socket, insert in the correct spot.... makes a clean hole, no cracking, no bullshit..... easy install.... get em from a rod shop, if you hav troubles, johns rod n custom in melb has them
I've only seen them in the tail/stop lamps in Beetles....
My Son has them in his beetle...
it depends where You put them, to how they work...
centre mounted - should show the blue light at a Distance but red up close...
Higher mounted- should show blue light up close and red at a distance...
Too illegal for Me.... I might do many illegal things... but that isn't one of them... they were very popular with Beetle owners many years ago....
I think I saw Classic Vee Dub with them at Valla...
Adam_C ·
Arent you man enough lee?
haha :P
robnjo ·
hehehe:thumb
mnsKmobi ·
Can someone post a picture of these "blue dots" for those not in the know?
PurpleT3 ·
I second the motion. What the hell is a blue dot?
oval TOFU ·
I concur. I don't know WTF a blue dot is either!
CoopGirl ·
Ok, this isn't a pic of a blue dot on a VW but I think you get the idea..
http://www.belairautoparts.com/49-52%20Parts/50_blue_dot.jpg
[Edited on 18-8-2004 by CoopGirl]
jenz58 ·
Haven't you seen a blue dot shining at you from some cars at night...usually on 'rice'
....hope I'm not offending anyone here.....:sandrine
.....I'm outa here.....
robnjo ·
..."Ricers" f@%& alot of kool stuff up, blue dots will always be rememberd as Hot Rod !
Adam_C ·
i know! fucking RICERS!!!!
