Anyone help...
I have installed a Tachometer in My Sons Baja Beetle.
It works OK.. but when the horn button is pressed, the tacho does about 3000rpm...
The Horn is operated thru a relay.. and both are connected thru the ignition system...
This happens with the ignition on or when the engine is going....
Tacho is not a VDO...
your wires are crossed.
no slow 63 ·
with a bit of work, your horn should rev to 6000rpm at least!
blutopless2 ·
without seeing how it is all wired it is hard to tell what could be wrong...
VWFREAK ·
Check out you earths and I agree with no slow 63, 6000 at least
GL1972 ·
3000 is probably the oscilation frequency of the horn.
