Items for subaru EJ20T & EJ20 NA conversion ( photos )
https://forums.aussieveedubbers.com/threads/27599/items-for-subaru-ej20t-ej20-na-conversion-photos
seagull ·
Air intake adapter
Note , this is a short unit no good for beetle & some of these are for my N/A motor .
[Edited on 19-8-2004 by seagull]
seagull ·
with air cleaner fitted
seagull ·
radiator fill point , there is a 5/8 fitting in the bottom and bleed line * from the radiator top of tank * and one to go to the expansion tank , they are 5/16 .
humpty ·
You've been having fun againe Neil!!!!
seagull ·
I just like subaru , sooo nice
I have some gear for you as well Simon .
Brad ·
mm looks good, so r u inverting the throttle body as well ?
seagull ·
No just buy one from you mate
can you show me what you made brad , ta seagull
Brad ·
hehe , yep ... I should have one on the showroom floor soon enough. I will take some photos tommorrow when I have the body off too fit the power steering rack in place for the last time before sending her north .....
seagull ·
O good would love a look :beer
seagull ·
how did you go there Brad Photo ?
Brad ·
well after wasteing 6 hrs fitting power assisted Rack and Pinion only to decide there was a better way and cut it all off again I forgot to bring the camera home so the pics are not with me...
I will get them up thsi week though. Also take some of the exhaust and cooling system for you .
seagull ·
Good to see some of your work , can you give me some insight as the inverted inlet ? cheers neil
Brad ·
it is a 180 degree bend
seagull ·
got you
seagull ·
placement of muffler and cat converter # The blue RHS is there just to hold in place for welding .
seagull ·
rear
exwrx ·
Seagull, looks very neat.
One question though, is there likely to be a heat problem due to the exhaust wrapping so tightly around the engine?
Maybe ceramic coating and/or heatwrap may help?
Not being critical, just trying to learn. 🙂
seagull ·
Ok the photos show the muffler * siting very close to the covers , there is a red pen holding the unit away from the covers ( all I could find at the time ) the muffler will be spaced away from the covers to aid cooling .I have also one more flange to add to the outlet of the cat as the left side <
the muffler has two 90 deg bends 180deg spaced apart so you can get to the spark plugs easy .The cat is spaced off as well , cheers seagull
O this is not in a car its in my trike * and yes I am very mad * 🙂
Jenny ·
What's the muffler inlet diameter, looks a lot like my alloy GPz900R ones thay I kept when I traded it in ... think they are 2 1/4"?
seagull ·
Hi jenny , the size is Dn 50mm or 2"
I was thing of making two of them but more weight and we can not have that can we .
did your brakes turn up ? please give us a look when you get them . neil
Jenny ·
Only the fronts have shown up so far, but I'm very happy with the quality of them.
Still waiting on the rears. Unfortunately I'm back at work now...
hazet ·
Hey seagull
How about one of these on your ej motor!!
hazet ·
2
seagull ·
hee hee , the front wheel would never see the ground , as you know you have been in maxes trike and felt the POWER , of subaru .
you running the above on the wifes subaru ?
I must catch up with you one day , seagull neil
boof2332 ·
Is that an eaton m62????
I like the idea alot....who made the manifold, is a standard one modified and made taller or does someone actually make it.....I can run it after the turbo.
Matt
hazet ·
Yes it is M62.Made for the ej22
The kit came out of CAPA in SA,the manifold came with it.
Very nicely put together
All you have to shift is the alternator
Jenny ·
looking good
seagull ·
After many hours , I moved the cat from the back to the side
seagull ·
another
humpty ·
Bloody hell Neil!
Looks like your exhaust will double as your bumpers!!! 😉
That aircleaner bracket that you made.....
How much for one of those?
Mates rates remember!
seagull ·
Yes thats the plan on the rear , you will see it soon .
Simon you cut it out I weld it for you no cost .
Did the clutch mods work out mate ?
humpty ·
I had a look down @ FORMAZ for an adapter like yours...
You can get a cast Ali job for $40!!! Might be EZR....Just cause I can't weld and you live on the "DARK SIDE"!!! 😉
Sofar so good with the FW....Getting close to the start up date....
Finishing off the exhaust on Monday hopefully!
seagull ·
Dark side ? , lazy bugger ,hee hee
If I had one made it would be yours but I out of stock .
Did you get a cat converter ?
humpty ·
Nah...Don't need a CAT (or so I've been told!) as my bus is early 85 model.
I'll check it out once she is up and running.
If I have to run CAT's I'll make some extracters for it at the same time...
seagull ·
Reno will get you !
