can you use the old fender beading?
https://forums.aussieveedubbers.com/threads/27751/can-you-use-the-old-fender-beading
Resto64 ·
As the heading says ,can i use the old fender beading ?
I took of the rear guards today and the original beading is still in good nick ,came off in one piece a bit grubby but will clean up nice.
Unity-28 ·
Yes, As long as its in good nic.....It will also match the rest of the car.....
Good luck.
N!
Resto64 ·
thanks for that good to hear 🙂
got any trick to keeping the bead lined up when putting the guard back on?
Desert Moose ·
Resto 64 wrote:thanks for that good to hear 🙂
Yeh, what I do is bolt the guard up with two turns on the bolts then feed it back in then nip the bolts up slow making sure it lines up ok🙂
give it a scrub up,,, make sure its not brittle and should be OK to use
Resto64 ·
i'll get straight on to it!!!!!
robnjo ·
even putting it in a bucket of hot water "from the tap" will help it.
