(no subject)
https://forums.aussieveedubbers.com/threads/2789/no-subject
70AutoStik ·
You'll probably find fitting extractors is your best bet. I picked up an "Empi" system for my T1 that made a magical difference, is quieter than the old one ("quiet" or Glass pack muffler) and was really cheap. The paint turned white the first time I took it for a decent drive, but it works great!
kombi_kid ·
dont see why you cant just that if you go LOW it mighht scrap hehehehehehe
rhys
KruizinKombi ·
Adz, I was having trouble with the standard extractors' thin, three-bolt flange. I took it to the exhaust shop and after 1/2 hour and $20 I drove out with a new two-bolt flange which was much thicker (10mm) to avoid flange leaks.
You can use any type of muffler on extractors, I have a hotdog on the type 3 and before that I had a standard oval muffler. The hotdog wasn't my choice, I just wanted something that gave me ground clearance and thats how it came back. What I really wanted was an oval muffler with inlet and outlet on the same side, so the other side could be tucked up behind the rear panel. 🙂
70AutoStik ·
Correct, you can fit any muffler to extractors. If your engine is close to stock, you may have problems with a lack of back pressure with some types (eg large hotdog.) With stock diameter pipes a quality glass pack is probably the best bet, unless you really like a lot of noise! I don't think you'll have a lot of trouble finding a suitable replacement, if you do, V-Dub Spares and Repairs in Fremantle, WA, boasts he can provide a full range.
kombi_kid ·
i have been told a lukey or genie turbo exhaust is good!
rhys
