? faulty ignition switch, Please help urgent
https://forums.aussieveedubbers.com/threads/27917/faulty-ignition-switch-please-help-urgent
Beetle bailey ·
I have a problem!!! No power at coil motor turns over but nothing happens. When i connect a wire from the ignition switch direct to the coil The motor starts fine but when I go to turn the key off but motor keeps on running until I pull the wire off. Please help as I am quickly going insane.
Beetle
[Edited on 26-8-2004 by Beetle bailey]
seagull ·
Ignition switch had it ????:alien
VolksFolks ·
join the club, my switch has also shit itself
andt
seagull ·
I have some new aftermarket ones here , there not a VW unit but work just fine
Beetle bailey ·
How much for the switches?
Ken
VolksFolks ·
i have splitty ones which are very nearly the same as the early german type 3's 'but' the type 3's have a inch long mounting bar so the screw holds it in place, which the splitty ones dont, will alloy welding 'melt' the inside seagul?
Andy
seagull ·
This would be better for a dash type unit , I have 4 of these
$50.00 each + post
seagull ·
one showing the thread & nut
SKEWtYpe3 ·
its not the small plastic barrel that sits behind the key cylinder is it?
thats all that was faulty w mine.
be careflu as there are many replacements that look the sameish but only certain ones will fit.
good luck
