Okay I have removed the circlips from the pistons pins but they dont want to move, I read in the manual to use a 'slide drift' or something like that. Is there some little trick to it ? It is a Type 1 1200cc if that makes any difference ?
pod 路
i used a bit of brass bar and tapped them out very gently
(it was turned down to use as spigot aligning tool) 馃檪
[Edited on 27-8-04 by pod]
1303Steve 路
I always use a trans spigot shaft, brass is good but get the end turned down so that it fits inside the pin.
silver 路
I use a big G clamp, and sockets small ones down the push side and big on the exit, I only take them out halfway anyway!
tassupervee 路
If "tapping" out the pins, always ensure that the pistons are firmly backed up so there are no side loads on the big end bearings when the pins are tapped.
Damage to the bearings can result.
The G clamp method avoids side impact loads on the conrods and pistons
L8tr
E
lugnuts 路
Or a bolt and nut and washers and a piece of wood and draw it out,thats right im a butcher.:kiss
Buggyboy 路
Thanks guys, will practise with the old motor to perfect the technique.
tassupervee 路
Lugnuts
LMAO!
Actually the drawbolt method you describe is as good as anything else...............LOLOL
Just looks a bit suss
L8tr M8
E
vw54 路
Drift and hammer ... they should push out easy unless the engine hasnt run for years.
lugnuts 路
tassupervee wrote:Lugnuts
LMAO!
L8tr M8
E
BIT SUSS,dam theyd make good plates!!!
BJ 路
Heat the piston and it will slide straight out, hot water will to the job or oxy, but go careful with oxy. Even the sunshine direct on to the pistons will also help. Has worked wonders numerous times for me.
