Another set of wheels
https://forums.aussieveedubbers.com/threads/28163/another-set-of-wheels
nbturbo ·
Just finished the first stage of my cradle to move a Beetle body around without a pan.I have made it so that it dismantles and stores easily and while bolted up can have 2 50mm tubes put through it and it will sit up on a 7x4 trailer for transport.I have used the offcuts from my carport job and some 40mm galv angle.When time permits,I will make up 2 off 50mm tube fittings with a 45 and 90 degree angles that will slide into and lock with pins each side which will allow the body to be tipped on a 45 degee and also on it's side for working on. These will be able to go in either side to work on all areas of a body. It has the body about the same height as a standard Beetle.
seagull ·
well done :beer
vwking ·
hmmmmm now ya got me thinking::beer
