H E L P !! lost my chip for Key in Golf
https://forums.aussieveedubbers.com/threads/28278/h-e-l-p-lost-my-chip-for-key-in-golf
karmen ·
the bloomin thing is tiny and the same colour of the asphalt it fell on. SHould have been glued in. key popped open as the lock got stuck...
Key does NOT work ignition as the chip had a memory ...bla bla
got a spare but can anyone tell me where I can get the chip duplicated.
Austral MTRS Brissie said no can copy - there is $$$ in it -hey
new Key $295.00 ! !
Any techno brains out there??:cry:cry
karmen ·
sorry its actually a Seat Cordoba GLX
225,000 on the clock
almost all Golf VW
looking for another sooooo economical and unbreakable
(except the key)
karmen ·
thump
JETTABOY ·
If your not too fussed about the remote locking part of the key, you van buy a volkswagen blank key with an imobilisor chip in it and use that!!!
Part # 1Ho 837 219A
Your vw or seat dealer should be able to program that key to your car!
I THINK!!!! by memory you might be able to pull the vw key apart and swap the chips!???
karmen ·
How much for that jettaboy??
Thanx for the part Nr
do or did you work in the parts dept ?
a complete copyone from bris as I said is $298 !!!
karmen ·
still lookinn !!
please
VolksFolks ·
Here, is this the same sorta thing, my passat uses this type
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7922417771&category=33723
Andy
VolksFolks ·
This is how to reprogramme the chip
Check with your local VW Dealer for compatibility. If you just want to change the insides because your remote body is looking bad that will work. You just pop the top off of your key then put the key that works in the ignition. Next turn the car on but don't start it. Get out of the car leaving the key ON.Take your new (old key) thats attached to the new remote and put it in the driver door. Pump the key to the right twice, the second time hold it for twenty seconds then let go and hit unlock. Its that easy don't get caught up in the secrets...its no secret! Don't waist your time with the uncut key hype! Good luck!!
sounds easy eh
Andy
karmen ·
thanks Andy
will look into it asap and let you know.
Will also try German e-bay
