my fan belt wont go on!!! yay all fixed!!
https://forums.aussieveedubbers.com/threads/28305/my-fan-belt-wont-go-on-yay-all-fixed
Vw nutter ·
hey guys i need some help oh how to put on my new fan belt on my 2lt??? i cant seem to loop it around the two pulleys (the big one and the small one), can some one tell me how to put it on?? do i need a speial tool or something??
thanks
[Edited on 8-9-2004 by Vw nutter]
barls ·
there is an adjuster on the alternator but im not 100% sure where cause its been a while since i played with a stock 2L in a kombi. the bolt for the adjuster is above and on the tin ware behind the pulley
Vw nutter ·
what does this adjuster look like?? im new to 2lters so im a little slow!
maybe send us a pic of what your talking about?
barls ·
id love to mate but i drive a bug and even the one with that motor is not the same set up. im working from memory from when i worked with my old man. it is a a allen key head from memory. and it sits in a long slot, you loosen it and the alternator slides to the left so you can get the belt on. to tension the belt lever the alternator to the right
Robo ·
There' a little rectangular plastic cover over the hole in the tinware on the uper right of the alternator. take this out and you will see a allen head set screw. This is the adjuster to slack off the tension so you can move the pulley closer and give you the clearance required.
Rob...😎
barls ·
thanks robo i couldnt remember
PurpleT3 ·
Lucky I happen to have a 2L sitting in the garage.
Remove covers and loosen the screw with a 5mm allen key. Push the generator up and left until you can pull the belt off.
[Edited on 5-9-2004 by PurpleT3]
Robo ·
He He
A picture's worth a thousand words!
Rob...😎
Vw nutter ·
thanks guys
yous rock!!!!:bounce:bounce:bounce
Vw nutter ·
this is the bolt but it wont move!!:cry
Vw nutter ·
the bolt undoes but when i try to slide it up or down it doesnt budge. am i missing something??
do i have to take off the tin ware??
kombikim ·
ok THAT BOLT HAS TO BE LOOSENED A BIT ,
then, have a look at the lower side of alternator & you will see round end of another bolt, at the back end of this, accessable from underneath is a 13mm nut, this has to be loosened also
barls ·
had to ask my old man on this one. under the car you have to undo the air deflector plate which has 4 bolts holding it on. once you get this off get a torch and look up there and you will see a 13mm bolt at the bottom of the alternator crack this one off a tad adn you should be able to move the alternator
Vw nutter ·
ok i will try it now!
thanks
Vw nutter ·
wooooohoooooooooooo i managed to to it, i needed to use some elbow grease and use a srew driver to lift it up but i got it in the end thanks to you guys, really appreciate it.
thanks again:beer
barls ·
not a problem it just one more dub back on the road
