Aussieveedubbers · VW Site of the Week
New Kubels!
https://forums.aussieveedubbers.com/threads/28338/new-kubels
Boozer ·
they're replicas. boo hoo. but they're new!
http://www.intermeccanica.org/
Boozer ·
Intermeccanica TYP 82 Specifications
IM TYP 82 KUBELWAGEN
Standard features
o Gel-coat color
o vinyl upholstery
o denim vinyl top / side curtains
o marine carpeting
o VDO original style speedometer and warning lights
o 3 point seat belts front, lap belts rear
o 2 wiper motors with independent controls
o high efficiency heating and defrosting with speed booster fan
Options
o 1600 cc engine with twin carb, 75 HP
o 2100 cc high performance engine, 135HP
o limited slip differential
o four wheel disc brakes
o boot cover in denim vinyl
o spare tire cover in denim vinyl
o top and side curtains in Stayfast cloth topping
o boot cover in Stayfast cloth topping
o air conditioning, CFC free
IM TYP 82 KUBELWAGEN COACH
Standard features
o Gel-coat color
o vinyl upholstery
o marine carpeting
Options - mechanical
o Mechanical Premount Package Number 1
including all parts listed below; installed-,
brake master cylinder, brake fluid reservoir, modified front suspension beam, front torsion bars, front trailing arms, front spindles for disc brakes, pedals, handbrake, handbrake cables, battery cables, accelerator cable, clutch cable custom length, custom shifter, shift bushing, shift rod, shift rod adjuster and coupling, fuel line, all hard brake lines, gas tank and
gas tank float
o -Mechanical Premount Package Number 2
including parts listed below, installed-,
steering shaft, cover tube, upper bearing, upper and
lower flange, rubber disc, new OEM steering box, clamp, pitman arm, long and short tie-rods, steering damper, original style 3 spoke alloy cast steering wheel.
o Mechanical Premount Package Number 3
including parts listed below, installed 2 powerful wiper motors, stainless wiper arms/blades, electric windshield washer
Options - body
o full heating plumbing with powerful 3 speed fan for excellent heating/defrosting; utilizing stock VW heat exchanger; includes cable control for heat exchanger.
o 3 point belts in front, rear lap belts
o boot cover in Stay-fast cloth topping
o set of 5- 5 1/2" x 15" road wheels; powdercoated to match trim with matching hub caps
MUD BASHING ANYONE ?? ·
LSD ohh me want me want
62deluxe ·
Hmmm, slammed on a set of 5-lug sprints, narrowed front beam, whitewalls,HOT motor............nice.:thumb
11CAB ·
Where's the replica Schwimmer??
