can anybody tell me about using a renault gearbox in a beetle with a scooby lump in already .or any links ,pics etc.any info would be very appreciated.馃槈
Brad 路
they are about 200mm longer and if you use the UN5 you will need substale mods to make it fit. The bellhousing is bolt on but you will need a sandwich plate to allow the kombi bellhousing to be used and will need around 75mm step off to allow output shaft to fit. This will give you an even longer box length which will casue even more issues. You will need to go over, under or through your torsion housing.
Ratios are good but in a Road Car with small ass rubber you will find 1st all but useless to you, I would suggest a 091 box would be a better fit and gearing setup.
doppelganger 路
cheers brad for the info .the box is going in a drag racer .the 091 i have already to go in over our winter and i have to change from swing arm to irs ,i was just looking at other options cos im fed up of breaking boxes.
Brad 路
I would go reno then as they are cheaper over thre and are much stronger than the 091.
doppelganger 路
is the un5 gearbox from the renault 21t?any pics or links to anyone who has used it that you know of?cheers brad for info so far馃檪
gayanne 路
Hey boys i hear that the reno 25gearboxes will take 500hps.Thinking putting one in the racecar.Great for drag racing still looking at ratios to see if worth it.You can pick them up for about $550 dollars.JVLRacing
Secoh 路
UN5 has a mindlessly low ratio (Buggy Brad only thinks of offroad applications and doesn't understand racing yet :P 馃榾), you want a UN1 gearbox from the R25, R25T or R30. R20 used the weaker box but is still good for about 300hp allegedly.
I sized up exacly this for my superbug and had to cut a hole in the floor to fit it. Yes it will fit, but not without cutting things.
check the sticky posts for tech links on these boxes.
